Re: Racing H: Update on the Update
Posted by rustred on July 15, 2012 at 18:34:50 from (184.151.222.96):
In Reply to: Re: Racing H: Update on the Update posted by BruceS. on July 15, 2012 at 18:26:51:
have you checked the weights where the pins go, i have seen those holes worn right out and cause the weights to stick. you may also need to adjust the linkage from hand throttle to governor to get proper adjustment at throttle shaft lever.
