Often time guys get into that governor and think they can increase the rpms of engine by making that link longer. No such luck. The weights and spring tension balance out to control speed. Harder the spring pulls on internal lever, faster engine will run. That link vertical adjustable link is to be adjusted so when gov weights are fully collapsed the throttle plate in carb is fully open, straight up and down. To adjust, take pin out, pull throttle lever wide open, pull up on lever that goes to carb, and then adjust the length of the rod clevis so pin just fit in.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
