Re: how to add power steering to super MTA
Posted by IAtractorKid on July 15, 2012 at 21:30:13 from (97.125.211.180):
In Reply to: how to add power steering to super MTA posted by B Andreasen on July 15, 2012 at 21:05:36:
Your best and cheapest setup would be priority valve off the pressure line of your live pump. The seperate pump is another option...one mounts on the side of the governor; ran off the crank pulley and requires cutting the fan shroud. The othe can be fit under the hood in front of the manifold and run off the water pump/alternator belt.
You can have any combo you want but the seperate pump are most commonly used with the charlynn torque generators that will fit under the hood. Behlen is the larger unit that would mount above the gas tank.
