Re: Carb cleaning
Posted by rustyfarmall on July 16, 2012 at 09:36:25 from (67.55.162.174):
In Reply to: Carb cleaning posted by The Red on July 16, 2012 at 08:50:07:
That brass idle metering jet does not go all that deep. If you use the hand drill method, you will know when you are all the way through. There is plenty of hole left after the drill is through the idle jet, so there really is not much chance of going too deep.
