Re: B vs BN
Posted by Davset on July 16, 2012 at 10:50:14 from (75.143.187.76):
In Reply to: B vs BN posted by charlie M on July 16, 2012 at 10:43:08:
If you"ve seen a BN, you"ve seen a B. They are almost identical, with the exception that the rear tread width is 8" greater on the B (and the asociated wider drawbar & floor pan).
The quick way to tell the difference is to look at the seat right-hand seat support. If it is flush to the inside of the fender, it is a BN, if there is a space (4"), it is a B.
