Re: 400 valve adjustment
Posted by Stemmy on July 16, 2012 at 13:20:06 from (206.49.63.193):
In Reply to: 400 valve adjustment posted by sflem849 on July 16, 2012 at 12:50:09:
as long as the firing order is the same, then it should be the same way.
