Re: how to add power steering to super MTA
Posted by IH fan on July 16, 2012 at 14:52:17 from (108.236.88.114):
In Reply to: how to add power steering to super MTA posted by old on July 15, 2012 at 21:05:36:
I'm going to recommend using a separate pump simply because when you idle the engine down and the priority goes to the steering, you may not have much left to operate the rest of the system. I don't know what the output capacity of the SMTA pump is, but on my 240U with a Char-Lynn TG, I lose enough flow to my 3 point that it will not move below about 1/3 throttle. Dad had a JD 60 with a Saginaw (GM) pump and it worked great with the Char-Lynn TG even at a complete idle and still had all the hydraulics.
