Re: Farmall C running on 2 cyl. only
Posted by Tom Fleming on July 17, 2012 at 03:34:19 from (67.20.233.126):
In Reply to: Farmall C running on 2 cyl. only posted by Eric Beyer on July 17, 2012 at 03:01:36:
a couple of things: do you have the firing order right? 1, 3, 4, 2 , clockwise rotation, starting at the 1 oclock position. also, make sure you have good compression in 3 and 4, with no sticky or hanging valves. Lastly, is the intake manifold tight and not leaking?
Start with those things and we can move on to others......
PS did this ever run right since you aquired it?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
