Why did you go to 12v. You need to remove all spark plugs and take a compression test. Then set the tappets and take another reading. Now if you have readings somewhat close to each other make sure your wires are in order on the cap and going to the rite plug. If you still dont have fire on all plugs must be bad wires or even bad plugs. What voltage does it have on the coil when engine is running is the resistor doing its job. You said restoring so you put it back to original and that is not converting to 12v.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
