Re: Farmall C running on 2 cyl. only
Posted by rustcollector on July 17, 2012 at 12:49:44 from (166.249.195.27):
In Reply to: Farmall C running on 2 cyl. only posted by Eric Beyer on July 17, 2012 at 03:01:36:
Eric,
Remove plugs and check gap. Then use a torch to heat the plug electrodes slowly until center conductor is red hot and any moisture and residue is burned out of the plug. Use pliers to start the plugs back in the cylinder while they are still warm. Tighten them, replace the wires and see if all cylinders will fire. This is a poor man's way of getting the tractor to run on all four until new plugs are purchased.
