Re: Racing H: Update on the Update
Posted by Jay Snyder on July 17, 2012 at 17:39:42 from (70.92.235.82):
In Reply to: Racing H: Update on the Update posted by BruceS. on July 15, 2012 at 13:09:05:
Have you checked the gasket between the carb and manifold? If the gasket is bad and doesnt seal it will suck air past it and the tractor will race. It basicually takes the throttle away from it. It will suck the air and it will pull the fuel up out of the carb. Check that first it is the cheapest and easiest. Good luck Jason
