Re: H overdrive
Posted by gene bender on July 17, 2012 at 18:23:21 from (67.55.226.123):
In Reply to: H overdrive posted by David G on July 17, 2012 at 17:44:17:
Overdrive will not give more speed in 5th gear. The speeds in overdrive will be around 6 in1st od 8 in 2nd od 10 in 3rd od and 12 in 4th depending on tire size and engine rpms your gov is set. But 5th will be the same.
