Re: Broken glass fuse in a 400
Posted by gene bender on July 17, 2012 at 18:24:38 from (67.55.226.123):
In Reply to: Broken glass fuse in a 400 posted by Evan from iowa on July 17, 2012 at 16:19:35:
Probably need a new fuse holder whil you are at car quest
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
