Re: Bottom drain plug on M carb won't budge
Posted by Phil Tibbetts on July 17, 2012 at 18:42:53 from (208.93.14.38):
In Reply to: Re: Bottom drain plug on M carb won't budge posted by Patrick HMD on July 17, 2012 at 15:41:02:
Heat may still help. Heating will not harden it unless you cool it suddenly. I am a retired machinist and have removed hundreds of rusted and frozen bolts and pipe fittings over the years. Just take your time and if you decide to drill it out start with a small drill and slowly work up. Be careful not to get into the threads on the bowl. When you get to 1/4 or 9/32 heat the pipe plug inside the hole you drilled to light red, then let it fully cool and you can probably turn the plug right out. Hope this helps. I didn't realize that you had a cast iron bowl before.
