Re: Re: Re: Re: Rear axle gasket
Posted by Dick on October 03, 2000 at 14:48:15 from (205.188.197.27):
In Reply to: Re: Re: Re: Rear axle gasket posted by Bergen on October 02, 2000 at 20:18:52:
I use regular gasket material sold in sheets at automotive supply houses. I have used other materials like fibre board, card stock and heavy construction paper, and usually have had no difficulties. But gasket material is designed as such from the get go and will hold up under all conditions. Thick rubber inpregnated cork works well for valve cover gaskets but holes must be punched rather than cut with a ball peen hammer.
Those low cost Chinese gasket punches have worked well for me, just be careful not to knick an edge or clean cuts will be impossible.
Post A Followup
: Re: Re: Re: Re: Re: Rear axle gasket
