Re: Farmall M transmission fluid leaking
Posted by The Red on October 03, 2000 at 15:09:23 from (12.75.196.188):
In Reply to: Farmall M transmission fluid leaking posted by Tis on October 03, 2000 at 14:56:00:
Tis is your leaking occuring where the axle casings bolt to the transmission casing?
13 gallons is the correct amount of 90W for the transmission. There is a side drain plug near the clutch pedal. If fluid flows out, you are full.
Post A Followup
: Re: Re: Farmall M transmission fluid leaking
