Behlen units use a gear motor which is inherently larger than the Charlynn gerotor or geroller torque generators. Unless you have a lot of room under the hood, the Behlen should mount off the steering support in front of the steering wheel. Charlynns are much sleeker and are still in production at Eaton's Shawnee plant (meaning parts are available)... not sure if the Behlen is still built.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
