Re: Bottom drain plug on M carb won't budge
Posted by rustyfarmall on July 18, 2012 at 06:31:06 from (67.55.162.174):
In Reply to: Bottom drain plug on M carb won't budge posted by Patrick HMD on July 17, 2012 at 15:02:58:
Hopefully the carb is off the tractor AND disassembled? If so, grab your torch and heat the area around the plug cherry red. Let it cool a bit and then start dousing it with your favorite flavor of penetrating oil. It will smoke a little, but douse it again when the smoke stops and then walk away. Come back in about 30 minutes, grab that plug with your vice-grips and remove it. I've done it that way on every carb I've ever rebuilt and never damaged one. Yes, it is a 1/8" steel pipe plug.
