Re: WD-9 Radiator Mounting Pads
Posted by Harold H on July 18, 2012 at 07:51:47 from (12.23.230.67):
In Reply to: WD-9 Radiator Mounting Pads posted by WD9ER on July 18, 2012 at 06:26:48:
I think the pads are more like 3/16" maximum thickness. Anyhow, you need the slight pading, do not mount the radiator metal to metal as it will cause problems in the long run. You should be able to make your hose flex enough to hook up at any rate.
Harold H
