Re: 706 PTO common problems
Posted by The tractor vet on July 18, 2012 at 09:58:50 from (76.212.234.198):
In Reply to: Re: 706 PTO common problems posted by Rtkman on July 18, 2012 at 09:24:47:
Well if your would have paid more attention to my earlier post you would not have pulled the unit . and if the valve came out the top the pin is broke . BUT since ya got it this far out now would be to put a new clutch pack in it and order the test fitting and a gauge so you can adjust the pressure . as back in the archives i posted the Case I H part # for the fitting and when you get it you will have to make up a Hdy hose with the correct JIC fitting and what ever the gauge needs.
