Re: Bottom drain plug on M carb won't budge
Posted by Patrick HMD on July 19, 2012 at 00:10:43 from (75.0.238.186):
In Reply to: Bottom drain plug on M carb won't budge posted by NoNewParts on July 18, 2012 at 11:44:21:
Wow, thanks for the tip on the drain cock. Gonna get one. I'm always up for a little embelishment.
Finally got it out today. Ended up using heat and pb blaster. Got the plug bright red, then started wiggling it with the vice grips. Felt good to see it finally break loose because I still had my doubts.
It seems so trivial now that it's done. But I'm sure there will be others just as stubburn when I start doing the tear down on the 49 M. Not there yet. I'm just trying to get it to run right for now. Finnish up the carb tomorrow, then start up on a gas tank flush, then coating. Once that's done I'll be in lot better shape.
Thanks guys. Patrick
