Posted by El Toro on July 19, 2012 at 11:11:54 from (108.3.148.85):
In Reply to: 52 H engine overhaul posted by Robin Hood on July 19, 2012 at 08:09:38:
If that engine has a lot of wear time on it I would pull the engine and tear it down completely. Take pictures and make notes. Separate the parts as you remove them. Use cardboard boxes and mark the box where it was removed. Saves a lot of time during the reassembly.
Pull the crankshaft and have it measured for wear at your local auto machine shop. Buy your bearings from them. Pull the camshaft and check the lobes for wear also have new cam bearings installed. If you have a problem removing the sleeves have the machine shop to press them out and new sleeves in. Take the head along and have the valves ground. If the valves are getting thin I would replace them along with new springs. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
