She said, It's a sickness
Posted by CharlieNJ on July 19, 2012 at 16:35:03 from (76.117.68.151):
third party image
third party image
third party image
third party image
Well that's what the wife said when I came home with this Super C. This Super C is number 6 to my farmall fleet. Of the other five, three are in service, one is now split in the shed for an overhaul, and one is getting a comprehensive overhaul. So I did not need another project. As I only gave $100 for it I thought I sould been awarded a medal.
This tractor was sabotaged, someone put sand down the oil fill. The PO "flushed it" but when I had the valve cover off there was still fine white sand in the nooks and cranies. It needs a starter, manifold, carb, and magneto, but I have spares of all of those. When I stuck a finger in the radiator I thought I saw oil, a closer look and it was Barsleak. Radiator was holding fluid, so, I used the sparkplug air fitting in each hole, put 100 pounds to #2 and bubbles came up in the radiator. Hope its just the gasket. PO ran it after the "flush", I might try to run it for five minutes to see how it runs before a total overhaul.
So how did I do?
Best Regards,
Charlie
