Posted by Nebraska Cowman on July 20, 2012 at 05:01:13 from (64.134.166.99):
In Reply to: Re: F-20 flywheel posted by GNPfatboy on July 19, 2012 at 19:46:01:
Yes, I have been told that the bell housing will fit between the frame rails but I do not know how. I have always had to take one frame rail loose. Maybe the bell housings are not all the same and some do fit.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
