Re: Farmall B Generator Belt Starting Problems
Posted by mkirsch on July 20, 2012 at 05:38:51 from (64.80.110.74):
In Reply to: Farmall B Generator Belt Starting Problems posted by tshlance on July 20, 2012 at 04:53:22:
There is no need to remove anything, not even the hood, to change the belts. Taking the hood off does make it a bit more convenient, but it is not absolutely necessary.
Simply loosen the generator mounting bolts and swing it in toward the engine to remove the generator belt. It may be necessary to detach the top brace entirely to get enough swing.
To remove the fan belt, loosen the big nut behind the fan assembly and slide it down in the slot.
You may need to work a little to get the belts off because there isn't a huge amount of adjustment. Just put a little muscle into it.
