Re: Farmall B Generator Belt Starting Problems
Posted by El Toro on July 20, 2012 at 05:43:04 from (108.3.148.85):
In Reply to: Farmall B Generator Belt Starting Problems posted by tshlance on July 20, 2012 at 04:53:22:
Check the specific gravity using a hydrometer on each cell to see what readings you're getting. Should see around 1.275 on a fully charged battery. If one cell is very low like 1.100 you have a dead battery cell and you need to replace the battery.
If the specific gravity readings look ok replace your battery cables with 00 cables that have soldered lugs. Clean all connections until they're shiny and that includes where your battery is grounded. Don't use cables any longer than necessary. As Gene mentioned your generator belt has nothing to do with your starting. Hal
