Re: Farmall B Generator Belt Starting Problems
Posted by old on July 20, 2012 at 09:18:46 from (209.86.226.27):
In Reply to: Re: Farmall B Generator Belt Starting Problems posted by tshlance on July 20, 2012 at 07:22:24:
Pull the plugs out and try to spin it over. If it spins easy then you know it is not a belt that is to tight. Also watch for fluid to come out of any of the plug holes and if it does you could have a problem with a head gasket or you may have some water in the cylinder hyd locking it
