Re: WD-9 Radiator Mounting Pads
Posted by Red Mercury on July 20, 2012 at 12:22:14 from (204.112.1.11):
In Reply to: Re: WD-9 Radiator Mounting Pads posted by WD9ER on July 18, 2012 at 08:21:00:
I just took at look at the shroud/fan clearance on a WD-9. Top=1/2 inch, Bottom=1/4 inch, Left side=1/2 inch, Right side=1/4 inch. Obviously not perfectly centered, but enough clearance that there aren't any problems.
The pads under the radiator look like they were cut from truck mud flap and they were approximately 3/16 inch thick. I likely made those about 15 years ago when I had the tractor torn down for repairs. I am a little fussier now--I would probably try to find the correct rubber insulator.
