Hydraulic for Loader on 856
Posted by JWCarp on July 20, 2012 at 13:25:58 from (72.37.171.84):
Is there a place on an 856 to pick up hydraulic from the main pump for a loader. I currnetly have the loader running off the aux valves but I can't do that and have the loader hooked up at the same time. I am hoping that there is someplace on the valve spools under the seat to run to another set of valves that I can mount on the loader. Then I can have the valves for the loader and the regular aux valves for the baler. Thanks for your input.
