Re: 706 won't steer, hydraulic issues
Posted by Rtkman on July 20, 2012 at 14:57:05 from (75.120.180.12):
In Reply to: 706 won't steer, hydraulic issues posted by John V. on July 20, 2012 at 14:42:19:
Keep turning the wheel and get the system primed. If the MCV pump is weak, it sometimes helps to turn the wheel keeping pressure on the system and then pump the brakes. Many times it will be necessary to remove the 5/8" plug on the side of the MCV valve plate and then put a little air pressure in the fill tube. Be ready to shut it down, it will make a mess once it starts to pump again. Replace plug, start it up and hopefully your good to go.
If it keeps doing it, replace the MCV or look up "tractor vet"'s previous discussions on MCV pumps.
