Re: Ih 684 thoughts
Posted by jimb2 on July 20, 2012 at 16:35:19 from (184.71.240.234):
In Reply to: Ih 684 thoughts posted by outdoors on July 20, 2012 at 14:42:23:
Hi, my brother has both 454 and older 684 with
same shifter as 454. I have used both for many
hours.
The D-239 is a harder to start engine in the
winter and will consume more fuel. The 684 may
have a T/A and the 3pt will be a cat II lower
links. You can buy insert to make it cat I or
change the pins on your 3pt implements. 454 is a
better tractor in tight spaces with shorter
turning radius.
Both engines are very reliable.
JimB
