Re: 706 won't steer, hydraulic issues
Posted by The tractor vet on July 20, 2012 at 16:37:40 from (76.212.234.198):
In Reply to: 706 won't steer, hydraulic issues posted by John V. on July 20, 2012 at 14:42:19:
IF everything is slow first replace the hdy. filter Then fill to the full mark then add and extra three to five gallon. Start the tractor and run the engine at 1800 to 2000 rpm and turn the steering wheel to the left and keep turning it . This SHOULD get it to pick up prime , and pumping the brakes will do nothing . Since i can not see the tractor i have no idea what is going on .Ya ya can pull the 5/8th plug out off the back of the MCV but if it does pick up prime your going to need a few bags of floor dry . You can pressurize the rearend with compressed air thru thew fill tube BUT here again you can end up with one hello of a Hy Tran rain storm when you release the pressure , Don't ask how i know that.
