Do you have a crank for it? I think they all came with one. With a crank you can get the feel of the engine. Does it pull start? If you pull start it you can verify that the engine is OK. Use a set of jumper cables to bypass the battery cables. Don't just start throwing parts at it until you have some idea where the problem is!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
