Re: Farmall B Generator Belt Starting Problems
Posted by d deatty on July 21, 2012 at 06:36:24 from (24.12.128.253):
In Reply to: Farmall B Generator Belt Starting Problems posted by tshlance on July 20, 2012 at 04:53:22:
I would make sure the new battery is good. Then check cables as said by others.The switch can be taken off and cleaned.That old of a tractor the starter may be dragging.As for the generator loosen thr big nut on the back side of fan andjust loosen the bolts on gen. Then remove the belt from gen and slip it under the fan belt and over the fan blades.Put the new belt on reversing the way it came off. Tighten the fan belt first and then do the gen.
