Re: Dip Stick vs Check Valves on Farmall Tractors
Posted by FBH44 on July 21, 2012 at 07:44:41 from (64.85.215.101):
In Reply to: Dip Stick vs Check Valves on Farmall Tractors posted by John Quillen on July 21, 2012 at 06:47:42:
I installed a dip stick on my "50 H. There"s a boss on the right side of the block that I drilled through. It took about 2 3/4" of drill, had to remove the pan and clean all the cuttings out. Had to tap the hole for a small pipe, and install the stick. It cleared the crank rotation by only about 3/4".
I like it a lot, butman it was a real hassle. That might be why IH didn"t install them, too much trouble. Highly recommended, but lots of work.
