Re: Dip Stick vs Check Valves on Farmall Tractors
Posted by Harold H on July 21, 2012 at 07:50:40 from (12.23.230.67):
In Reply to: Dip Stick vs Check Valves on Farmall Tractors posted by John Quillen on July 21, 2012 at 06:47:42:
Your neighbors tractor with a dip stick either has a replacement engine or had a dipstick added during its life. Generally speaking, as long as the distilate engine was available the petcock was the norm. Some industrial engines and tractors had dipsticks because they were specificly for gasoline. Distilate was the standard fuel on Farmall and McCormick tractors through most of the 1040's and was an option thru the 50 series ie 350, 450, etc. after which dipsticks became the standard. When you burn distilate or kerosene, you have to be able to drain off the diluted oil, thus the petccks were required.
Harold H
