Listen to the noise at idle, go to the carb side and move the governor to carb rod a little, (enough to make it change speeds a fer hundred RPM, not much. Listen to that knock, if it changes or goes away irregularly, and then comes back, it could be a wrist pin. I would not worry about wrist pin noise, engines can live for many years with a noisy wrist pin. If the noise stays consistant, and seems deep in the engine, Living with it might be OK. Keep tabs on the oil pressure, If the needle fluctuates radically at idle, I would probably remove the pan and check bearing clearances. If the pressure is OK, just keep an ear to the noise, and if it progersses, or changes, I would suggest a teardown sooner than later, as expenses mount as connecting rods find daylight. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
