Re: Bolt Question
Posted by randy hall on July 21, 2012 at 16:33:15 from (216.255.39.32):
In Reply to: Bolt Question posted by Jim Paterson on July 21, 2012 at 14:09:33:
fastenal will have your bolts you need in grade eight. if you buy them from ih you will have to mortgage your firstborn. i don't use the bend over locking tabs. your new car doeesn't have them it that motor runs three times faster than your h does. never use a lock washer they can break and fall out. you don't need any locktite with the proper torque the bolt is streched a little and the tension holds it from working out. ps a good mechanic will always use new rod bolts.
