Re: 48 M will not stay in 5 th gear
Posted by CNKS on July 21, 2012 at 17:24:51 from (216.144.104.128):
In Reply to: 48 M will not stay in 5 th gear posted by smcIND on July 21, 2012 at 16:19:15:
5th is direct drive, the shafts are splined, one slides inside the other -- most likely the splines are worn, thus it won't stay engaged. Thus the shafts have to be replaced. I think you can see by removing the belt pulley, but to get the shaft and gears out you have to remove the trans cover, don't know if the belly pump has to come out or not, but the tractor does not have to be split. It also could be as simple as reshaping the bottom of the shift lever.
