Re: Super C question
Posted by CNKS on July 21, 2012 at 17:41:37 from (216.144.104.128):
In Reply to: Re: Super C question posted by Brett Helmkamp on July 21, 2012 at 17:13:11:
I mowed with my Super A, good battery and connections (tractor was restored a year ago), everything was ok. Next morning it would not even grunt. After trying several other things, I found that the starter switch was not making good contact with the brass contact under it. I did not replace the switch, but filed the brass thing and it started. Every one mentions 00 cables, on the A,B,C they are overkill, what you need is clean connections, which are much more important than the cable size, including my Super H I have 2 gauge. I have a Super A and a C with the factory ground connected through the battery box, zero problems with that also. The Super A got that connection a year ago, the C has had it for the last 10 years.
