Re: Another carb adjustment question
Posted by CNKS on July 21, 2012 at 17:52:27 from (216.144.104.128):
In Reply to: Another carb adjustment question posted by BigTone on July 21, 2012 at 17:29:02:
Which jet do you mean? The main jet screw is turned in at full throttle until it stutters, then out until smooth. If it does nothing it is still plugged. Same thing for the idle jet at 600 rpm or so. I have never had the desire to turn out the main jet until it smokes, you want a lean condition, not rich, that is why you turn it IN first and then out until it is smooth, no more than 1/4-1/2 turn after that. This is all in the Operators Manual, which you obviously need. One other thing. The M carb has the choke lever and rod on the outside of the carb, the SM on the inside. If you have an SM carb, forget the main jet adjustment and turn it out 4-5 turns. The SM idle jet is adjusted the same as the M jet.
