Re: Another carb adjustment question
Posted by JRSutton on July 21, 2012 at 18:00:39 from (75.130.109.233):
In Reply to: Another carb adjustment question posted by BigTone on July 21, 2012 at 17:29:02:
one thing I'd add to the other advice is once you do as they say - drive it up a steep incline before you put your screw driver away.
You want to test it under some load. If it starts sputtering, back it out a little more, but at that point - go in small increments till it's right.
