Re: Dip Stick vs Check Valves on Farmall Tractors
Posted by SadFarmall on July 21, 2012 at 18:04:03 from (121.79.19.36):
In Reply to: Dip Stick vs Check Valves on Farmall Tractors posted by John Quillen on July 21, 2012 at 06:47:42:
In Australia, the kerosene powered Farmalls had petcocks and the diesel versions had dipsticks. The AW-7 Diesel we had was fitted with a dipstick. Personally I have never found either to be more or less hassle than the other. Just one of those things. 1939 Farmall M startup procedure in the morning was to drain the oil (when running on kero) or just check the oil was at the top petcock (when running on petrol). AW-7 Diesel, you had to unscrew the dipstick and withdraw it to check oil level (could require considerable force, especially in the cold). I like the petcocks, because they can never give a false reading.
SadFarmall
