Re: Another carb adjustment question
Posted by GordoSD on July 21, 2012 at 18:12:39 from (64.33.250.162):
In Reply to: Another carb adjustment question posted by BigTone on July 21, 2012 at 17:29:02:
Were you trying to adjust the idle jet at full throttle? The idle jet only meters fuel for idling conditions, ergo "idle jet" . Fiddling with that at full throttle is counterproductive. Go back and set the "idle jet" at idle, and then the load (main) jet at higher and load conditions.
Which manual are you using?
