Remove the belt pulley or cover plate (whichever you have) and you can readily see the area of interest. In addition to what CNKS said, there is the possibility of excessive wear in either the pilot bearing or the bearings in the input shaft assembly or some of both. Under load, the two shafts will be misaligned enough to allow the gears to "walk out".
With the trans open, engage 4th gear and grab the front of the mainshaft and try to wiggle it around. Excessive play will be obvious. You'll be able to clearly see the splines on the inside of the 4th sliding gear and at the back of the input shaft. Try wiggling the input shaft as well.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
