504 Dies When Hot?
Posted by JHubnuts on July 22, 2012 at 18:45:10 from (216.158.173.228):
Did some plowing today, and after about a 1.5-2 hours of trouble free plowing i bogged down in a spot and didn't lift the plows quick enough and stalled. It didn't want to start back up easily. When i did get it started it would loose power sporadically after it got hot, and eventually loose power enough to stall, even after pushing the clutch in. Did this 4 or 5 times today. Temp gauge doesn't show any change in temp. But that's probably busted. Radiator didn't boil over or steam, and is full. Would seem to happen after tractor was good and hot. was low 90's here today. plowed in 2nd drive and 3rd ta, harrowed in 2nd drive, throttle 3/4 to full. Did i damage something when i stalled the first time? I'm just not sure how to fix this. Any help would be appreciated.
Thanks.
Jason
