Posted by oldtanker on July 22, 2012 at 22:39:10 from (66.228.255.239):
In Reply to: Super C oil pressure posted by J.D.HEICHEL on July 22, 2012 at 22:19:09:
Did you rebuild the oil pump????? I have the same problem with one I just did because I was too cheap to do the oil pump while it was apart. I'm kicking myself in the butt over this one but once the summer work is over the pan is coming off and I'm doing the pump.
FYI cam, crank bearings and oil pump will affect oil pressure.......valve guides/seals will not. All the guides will do is make sure the valves are seating where they shoud and the seals control oil consumption.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
