Re: Super C oil pressure
Posted by Bobinva on July 23, 2012 at 05:50:37 from (108.48.43.190):
In Reply to: Super C oil pressure posted by Eastsider on July 22, 2012 at 22:19:09:
Don't worry...Super C's were made to run all day on 8psi oil pressure. If you were at the first mark on the guage you are fine...On later models the last mark is labeled "75" (on my 230)...sooo the first mark is approx. 15psi. I use 15-40 diesel oil in all my tractors. BobinVA
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
