Re: Replacing Push/Pull Ignition Swith with Keyed Switch
Posted by rustyfarmall on July 23, 2012 at 08:45:54 from (67.55.162.174):
In Reply to: Replacing Push/Pull Ignition Swith with Keyed Switch posted by F4RM@11 on July 23, 2012 at 07:45:59:
It can be done, but I doubt you will find a keyed ignition switch that will fit where the original push-pull switch is located.
My 1940 M had a keyed ignition switch when I bought it, but whoever made that installation just bored a huge hole in the headlight bar, and then bored another huge hole to install the push button starter switch. Ugly as all get out and accomplished nothing because the wiring was exposed on the back side and could very easily be hot-wired. Wouldn't even need the key.
