Thank you very much for your help. Yes, the clutch felt good to me. I will know better once I am able to use the throttle and try out 4th and 5th gears. I wasn't able to adjust it quite as you had said because the pressure plate has a center hole with splines that run the IPTO so there was not a way to measure directly from the fingers to the flywheel surface. I just checked that they were the same height above the surface I was able to see and decided that would have to do. I was able to follow the detailed step by step instructions on how to adjust the main clutch and TA clutch linkages and that seems to have worked out well, the TA operates very easily and smoothly. I am sure I will keep having more questions to ask as I get closer to having it all back together. Zach
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
